Home > Think Tank > How To Speed Up Your Browser?
Jul 11, 2016
While some of that slowness can stem from issues unrelated to the browser, like ISP and computer hardware, there are some steps on how to speed up browser speeds.
Keep Fewer Tabs Open
Each tab hogs up a bit of RAM and when you have too many tabs open your computer will be bogged down. It doesn’t matter which browser you’re using; sure, some browsers may be more efficient with their RAM usage, but ALL browsers will take up more resources with each new tab. God forbid some of those tabs are Flash-based, because those take up even more RAM! Use bookmarks if you need to save items. If you want to mark an interesting article for later reading, use an extension.
Use Fewer Extensions and Addons
One of the biggest reasons why users will choose one browser over another is the plugin selection. Firefox calls them “addons,” Chrome calls them “extensions,” and other browsers will use other terms. But they all accomplish the same thing: extensibility and customization for your browser according to your needs. It’s no secret that many users have dozens and dozens of plugins installed. You’ve got plugins that spruce up the tab bar, improve readability, and block pesky ads. But just like tabs (explained above), each active plugin ends up using a little more CPU and RAM on your computer, which can result in some big performance hits. The quickest way to solve this problem is uninstalling every browser plugin that you don’t absolutely need. If your browser is slowing down, try disabling as many unnecessary plugins as you can.
Delete Cache and Browsing History
You need to clean your browser’s cache and history every once in a while. “But wait, isn’t the cache meant to speed up browsing?” Yes. Browsers will save certain pages and images locally so that the next time you visit that site, it can load them instantly without having to download them again. However, as your cache increases in size, the browser spends more time digging through those images and pages in order to find the right ones. Caches are most efficient when they aren’t filled with too much data.
Like any other machine, if you don’t keep your browser well-oiled and clean, it’ll start to hang and sputter and slow down your system. Keep the above tips in mind and your browser won’t feel as laggy as it normally does.
