Home > Think Tank > How to Set ChatGPT as Your Default Search Engine in Chrome and Edge
Feb 25, 2025
As AI-powered tools like ChatGPT become more integral to our online experience, many users are eager to make ChatGPT their go-to search engine. While traditional search engines like Google or Bing dominate, ChatGPT can provide an alternative search experience with its conversational AI and nuanced responses. If you’re looking to set up ChatGPT as your default search engine in Google Chrome or Microsoft Edge, here's how you can do it.
To integrate ChatGPT into Chrome, you’ll need to use a browser extension designed to replace or supplement your search engine.
1. Open Chrome. Click the three dots (menu) in the top-right corner of the browser, then select Extensions > Visit Chrome Web Store.
2. Type ChatGPT Search in the search bar, and press Enter.
3. Click Add to Chrome on the extension page and then confirm by clicking Add Extension in the pop-up dialog.
Click Add to Chrome
4. Once the extension is installed, click on its icon in the upper-right corner of Chrome. In the extension’s settings, select ChatGPT as your default search engine.
Set ChatGPT as Your Default Search Engine in Edge
Microsoft Edge doesn’t natively allow you to set ChatGPT as the default search engine, but you can manually add it in the settings.
1. Open Edge, click the three-dot menu at the top right corner, and select Settings.
2. From the left sidebar, select Privacy, Search, and Services. Scroll down and click on Address bar and search.
3. Under Search engines used in address bar, click on Manage search engines.
4. Click Add to create a new custom search engine and enter the following information:
  • Search Engine: ChatGPT
  • Shortcut: gpt
  • URL: https://chatgpt.com/?q=%s&hints=search&ref=ext
5. Click Add and then click the three dots next to ChatGPT to select Make Default.
select Make Default
By setting ChatGPT as your default search engine in browser, you can enjoy a more conversational, AI-powered approach to your searches. Whether you're looking for quick answers, detailed explanations, or a unique perspective on a topic, ChatGPT can offer a more direct and personalized experience.
How to Reset Firewall Settings in Windows DefenderHow to Enable or Disable Notification Badges in Windows 11 TaskbarHunt Down and Delete Duplicate Files in Windows 11 Without Third-Party Tools
