Home > Think Tank > Useful Tips for Dealing With BSODs
Jun 22, 2016
BSODs have a variety of root causes, but these tips will help you deal with many blue screens:
1. Use System Restore: If your system recently started blue-screening, use System Restore to roll its system software back to a previous state. If this works, you’ll know that it’s likely a software problem.
2. Scan for Malware: Malware that digs deep into Windows and gets its hooks into the Windows kernel at a low level can cause system instability. Scan your computer for malware to ensure buggy malicious software isn’t causing it to crash.
3. Install Updated Drivers: An incorrectly installed or buggy driver can lead to crashes. Download the latest drivers for your computer’s hardware from your computer manufacturer’s website and install them — this may fix BSODs caused by driver problems.
4. Boot Into Safe Mode: If your computer is blue-screening every time you turn it on, try booting into safe mode. In safe mode, Windows loads only the essential drivers. If a driver you’ve installed is causing Windows to blue screen, it shouldn’t do so in safe mode. You can work on fixing the problem from safe mode.
5. Check for Hardware Problems: Blue screens can be caused by faulty hardware in your computer. Try testing your computer’s memory for errors and checking its temperature to ensure that it isn’t overheating.
6. Reinstall Windows: Reinstalling Windows is the nuclear option. It will blow away your existing system software, replacing it with a fresh Windows system. If your computer continues to blue screen after this, you likely have a hardware problem.
Source from: How-To Geek
How to Change Your Hotspot Name and Password on iPhoneHow to Find Your Lost iPhoneHow to Use Windows Reliability Monitor to Diagnose Crashes
Understanding Windows Power Plans: Balanced, Battery Saver, High Performance, and Ultimate PerformanceWindows Update Delivery Optimization: How It Works & How to Disable It (2025 Guide)Should I enable or disable Trim of SSD?
