Home > Think Tank > How to Fix No Low Battery Notification on Windows 11
Sep 12, 2025
A low battery warning is one of the most useful features on any laptop. It prevents sudden shutdowns, helps save your work, and gives enough time to plug in the charger. However, some Windows 11 users have reported that the low battery notification doesn’t show up, leaving the system to power off without warning. If you’re experiencing this issue, here are some practical methods to bring back the low battery alerts on Windows 11.
Method 1: Check and Adjust System Notification Settings
The first step is to ensure that system notifications aren't being blocked entirely:
1. Press Win + I to open Settings.
2. Go to System > Notifications.
3. Toggle the switch to On if notifications are disabled.
Method 2: Enable Low Battery Notifications in Power Options
Windows 11 allows users to customize battery warning levels. If the low battery notification is turned off or set incorrectly, it won’t appear.
1. Press Win + R, type control, and press Enter.
2. Go to Hardware and Sound > Power Options.
3. Select Change plan settings next to the active plan.
4. Click Change advanced power settings.
5. In the pop-up, expand Battery > Low battery notification.
6. Set it to On for both On battery and Plugged in, then click Apply.
Set it to On
Method 3: Reset Power Plans and Run Power Troubleshooter
Sometimes corrupted power plans can cause notification issues.
1. Type cmd in the Search bar and select Run as administrator to open the Command Prompt.
2. Type following command and press Enter:
powercfg -restoredefaultschemes
This resets all power plans to their default settings
Type command
Windows includes a built-in troubleshooter that can identify and fix power-related issues:
1. Go to Settings > System > Troubleshoot > Other troubleshooters.
2. Find Power in the list and click Run.
3. Follow the on-screen instructions to complete the diagnostic process.
Method 4: Update or Reinstall Battery Driver
A faulty or outdated driver can prevent Windows from recognizing battery status properly.
1. Right-click Start and select Device Manager.
2. Expand Batteries. Right-click Microsoft ACPI-Compliant Control Method Battery > Update driver.
Expand Batteries
3. Choose Search automatically for drivers.
4. If no updates are found, right-click the driver again, choose Uninstall device, then restart the PC. Windows will reinstall it automatically.
Method 5: Check Battery Health
A deteriorating battery may not report charge levels accurately:
1. Open Command Prompt as administrator.
2. Type the following command and press Enter:
powercfg /batteryreport
Type the command
3. Open the generated battery-report.html file. Check the Design Capacity and Full Charge Capacity figures in the Installed Batteries section. If full charge capacity is significantly lower than design capacity (less than 60%), consider replacing your battery.
Method 6: Create a Custom Low Battery Alert
For those who want more control over their battery notifications, Windows 11 allows creating custom alerts.
Missing low battery notifications are annoying but usually fixable. By above methods, you can avoid sudden power loss. And if you want that extra assurance, custom alerts are a great fallback.
How to Fix iPhone Brightness Keeps ChangingHow to Turn On or Off Internet Printing in Windows 11How to Enable or Disable Live Video Translation in Edge
