Home > Think Tank > Fix System Guard Enabled But Not Running on Windows 11
May 20, 2025
Windows Security features like System Guard are crucial for keeping your PC safe from malicious attacks, especially those targeting the boot process. However, some users encounter the message “System Guard: Enabled but not running”. This can be confusing and concerning. In this guide, we’ll explain what System Guard is, and step-by-step instructions to fix it.
What Is System Guard
System Guard is part of the Windows Defender System Guard family of features that protects the integrity of your system during startup. It uses hardware-based root-of-trust and virtualization-based security (VBS) technologies to help ensure your PC boots securely and hasn’t been tampered with.
How to Fix “System Guard Enabled But Not Running”
Follow these steps in order to troubleshoot and resolve the issue.
Method 1: Check Hardware Requirements
Before troubleshooting software configurations, it’s important to ensure your hardware supports System Guard’s requirements.
  • Intel: vPro CPUs from Coffee Lake (8th Gen), Whiskey Lake, or later
  • AMD: Zen 2 or newer architectures (e.g., Ryzen 3000 series, EPYC 7002 series)
  • Qualcomm: Snapdragon SD850 or later
  • UEFI with Secure Boot enabled
  • TPM 2.0
  • Hardware virtualization
Method 2: Configure System Guard
Proper configuration through Registry Editor is essential to activate System Guard features.
Press Win + R, type regedit, and press Enter.
Step 2. Ensure System Guard is enabled
1. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\DeviceGuard\ScenariosSy
2. Find the Enabled value in the right pane, double-click it and set the value to 1.
set the value to 1
Method 3: Ensure Virtualization-Based Security is Enabled
System Guard relies on VBS to isolate secure operations. VBS must be active for System Guard to run.
Step 1. Open Local Group Policy Editor
Press Win + R, type gpedit.msc, and press Enter.
Step 2. Navigate to VBS Policy
Go to the following path:
Computer Configuration > Administrative Templates > System > Device Guard
Step 3. Configure VBS Settings
1. Double-click Turn On Virtualization Based Security, configure the following:
  • Set the policy to Enabled.
  • Select Platform Security Level: choose Secure Boot.
  • Virtualization Based Protection of Code Integrity: choose Enabled with UEFI lock.
  • Credential Guard Configuration: choose Enabled with UEFI lock.
2. Click Apply, then OK.
Method 4: Enable the Hypervisor
The Windows hypervisor is a foundational component for running VBS and System Guard. It can be manually enforced using BCDEdit.
Step 1. Run Command Prompt
In the search bar, type cmd, right-click Command Prompt, and select Run as administrator.
Step 2. Set Hypervisor Launch Type
1. In the command prompt, enter the following command:
bcdedit /set hypervisorlaunchtype auto
2. Reboot the system afterward.
Method 5: Enable Required BIOS/UEFI Features
Some features critical for System Guard must be enabled directly in the firmware settings.
Step 1. Enter BIOS/UEFI
Restart your computer and press the setup key (commonly F2, F10, Del, or Esc) during boot to enter BIOS.
Step 2. Enable the Following Options
  • UEFI Boot Mode
  • Secure Boot
  • TPM 2.0
  • Intel VT-x or AMD-V
The “System Guard Enabled But Not Running” message usually points to a misconfigured system rather than a serious security flaw. By enabling virtualization, Secure Boot, TPM, and core isolation features, you can restore full protection to your device. Always ensure your firmware and drivers are up-to-date, and consider creating a system restore point before changing BIOS settings.
How to Change Your Hotspot Name and Password on iPhoneHow to Find Your Lost iPhoneHow to Use Windows Reliability Monitor to Diagnose Crashes
Understanding Windows Power Plans: Balanced, Battery Saver, High Performance, and Ultimate PerformanceWindows Update Delivery Optimization: How It Works & How to Disable It (2025 Guide)Should I enable or disable Trim of SSD?
