Home > Think Tank > How to Fix the DeepSeek Server is Busy Issue
Feb 28, 2025
DeepSeek is a recently emerging AI assistant, however, as its popularity grows, users occasionally encounter the "Server is Busy" error—a common hiccup for high-demand platforms. This message typically arises during peak usage, network instability, or server maintenance. Fortunately, resolving the issue is often straightforward. Below, we’ll outline practical steps to restore access quickly and keep your workflow on track.
Method 1: Check DeepSeek Server Status
Before diving into more technical fixes, it's important to verify whether the problem is on your end or if DeepSeek’s servers are experiencing an outage.
Visit the official DeepSeek website or their status page to check for any ongoing server maintenance or issues.
If the server is down, you'll just have to wait for the issue to be resolved. DeepSeek frequently posts updates on its social media accounts where you can follow the downtime.
Method 2: Refresh the Page or App
Sometimes, a simple refresh can resolve the "Server is Busy" issue, especially if it’s due to a temporary glitch or a stalled connection.
  • For Browsers: Press F5 or Ctrl + R.
  • For Mobile App: Close the app completely and reopen it.
Method 3: Log Out and Log Back In
If refreshing the page or app doesn't work, try logging out of DeepSeek and then logging back in. This can help reset your session and clear any temporary data that might be causing the server connection to fail.
Click on My Profile and select Log out. Then, log back in with your credentials.
Method 4: Clear Cache and Cookies
One common cause of the "Server is Busy" error is corrupted cache or cookies in your browser. These stored data files can sometimes interfere with your connection to DeepSeek’s servers.
  • Chrome/Edge: Ctrl + Shift + Del > Select Cached images and files > Delete/Clear.
  • Firefox: Ctrl + Shift + Del > Select Cookies and site data > Clear.
Method 5: Disable VPN or Proxy
If you're using a VPN or a proxy server, it could be interfering with your connection to DeepSeek’s servers. Some VPNs or proxies may cause requests to DeepSeek to appear as though they are coming from overloaded or restricted locations, leading to the "Server is Busy" message.
  • For VPN Users: Open your VPN software and disconnect from the server.
  • For Proxy Users: Go to Settings > Network & internet > Proxy, and turn off proxy settings.
Method 6: Wait and Retry
If none of the above steps resolve the issue, sometimes the best course of action is to simply wait for a while and try again. DeepSeek’s servers may be temporarily overwhelmed, and the issue could resolve itself once the traffic load decreases.
Most "Server is Busy" errors are temporary and resolve with patience. If the problem persists for hours, the issue likely requires intervention from DeepSeek’s technical team. By following these steps, you can minimize disruptions and ensure smoother access to the platform’s services.
How to Adjust Audio Balance on Windows 11Fixed: You do not have access rights to Logical Disk Manager on DESKTOPHow to Turn On or Off Network Discovery in Windows 11
